Discuss Keston 130 oddities in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Karl Sabin
Hi there,
Have a Keston 130 and from cold boiler strikes as expected, gets good heat and then powers off for 5-10 mins, then strikes up and heats again. Not to room stat tho. Does this sound like a failing boiler thermostat?
Reply to Keston 130 oddities in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a...
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate)...
Renato
R
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
