Discuss Keston Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cr0ft
Are there any particular quirks to these boilers? Heard about them on my ACS Training course but seen my first one today. An existing customer who has moved into a house with them. How reliable are they in general?? Just want to learn a wee bit about the common faults with them before I head over on Friday.
Pressure was done to 0 bars as well when I popped out today. The whole heating system is UFH on a first floor flat. I reckon that rules out any leak from the pipework or the neighbours below would have been knocking by now. My bet is leaky heat exchanger :)
**** and watch the flues / small leaks as they will kill it
Have been a subsiduary of Ideal for some years now. Recent models may be re-badged Ideals.
Fair few round here simply advice customer to remove terrible boilers. Parts are silly expense got quoted a pump which comes as full block at about 400 quid while back. Also pcbs fail for fun and gas likes to leak around combustion chamber .
remove replace repeat every time you see one.
Two in a nursing home
Over 8 years I replaced every part inc heat ex, the only thing left was case, that was rusty !
I've stumbled across a few in my time and they've all been crap.
In my opinion of course. I should point out that, there are other crap boilers available
Reply to Keston Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
  • Article
The UK Government has today been told to do better when it comes to Heat Pumps and Hydrogen Boilers. A watchdog for spending has said that the...
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when...
