Discuss KESTON C55 FAULT CODE E 02 in the Central Heating Forum area at PlumbersForums.net
Do you have gas ? Eg pre pay meter
Yes there is gas and not on pre pay meter the boiler lights and then goes out . It keeps trying until it displays the E 02 fault code
Time for a gas safe engy I’m sorry to say
as shaun said need GSR out boiler needs a good service. make sure you get someone who knows these boilers as they are a pain. suggest ringing ideal who will send out a keston engineer who will have the parts on van to do this except heat exchanger which is no longer supported
As lads above have said a good gas engineer should diagnose your fault.
Seen alot of these and there never serviced properly and lead to further issues.
Don't be surprised if you don't like his findings.
Reply to KESTON C55 FAULT CODE E 02 in the Central Heating Forum area at PlumbersForums.net
What is the boiler flow temperature required to flag this 2965 fault code?. This, I believe, is a blocking code that trips the burner but...
Hello Wondering if anyone can offer any clues please // Potterton Promax 18 // Had an E1 error code, repressurised via with filling loop //...
Hello All I have an ecotec 630 with Sensohome controls. Should the fault codes shown in the boiler also be reflected in Sensohome control? All...
Hi All, Have a peculiar problem with my Gloworm Flexicom 30cx combi boiler, the main heat exchanger is getting red hot and fault coding on...
2K
After researching as much as I can to sort this problem, I keep reading that if your Ideal boiler has an F1 code and the pressure is low, it needs...
