Discuss Kitchen Cold tap not supplied by cold mains? in the USA area at PlumbersForums.net
Deleted member 113144
Hi There
Moved into a new build recently. Noticed that when I turn on the cold tap in the kitchen a pump in the attic seems to activate which would indicate that the cold tap in the kitchen is not fed directly by mains (however i am not a plumber so could be wrong)
Prior to noticing this pump activating, i had wondered why the Kitchen cold tap was not all that cold. There is also a cold tap in the garden which is properly cold and has much higher pressure
Questions I have are:
1 - If the kitchen cold is not mains fed, is this a breach of regulations, or just not good practice?
2- could i be wrong in my assessment of the situation, and is there a dead certain way to ascertain if the kitchen cold is incorrectly fed by the attic tank?
Many thanks
Turn the main stopcock off, preferably in the street, does the kitchen cold stop? Does the outside tap stop?
If both stop they are probably off the mains.
Can you trace the pipework?
It may be that the pump is for the rest of the house or maybe just the shower(s) and it's pressure switch is (possibly incorrectly) reacting to the pressure drop when the kitchen tap is opened.
Another way to check is to turn the power off to the pump either in the attic or at the consumer unit (turn off the whole house is needed) and see if the kitchen tap pressure drops or ceases altogether.
Does the kitchen tap run colder the longer it's been on?
The pipework to the kitchen tap is probably within a wall with insulation around it whereas the outside tap goes from the incoming mains directly outside.
Thanks for this advice.
Turned off the supply from the street. The tap in the garden stopped which means i definitely isolated the street supply.
Ran the tap cold tap in the kitchen and utility room and both flowed meaning cold water is coming from the tank
Is this a pretty bad oversight by the developer / plumber?
Hi there. I took advice from Ben-Gee above and isolated the street supply.
Cold tap in kitchen still ran so it looks like it is not mains supply in the kitchen.
Question i have now is, what formalities can i bring to the builder now to get them to remedy. I am very appreciative of the excellent advice but i imagine the builder will brush me off unless i've something concrete to pin on him regulations wise
Water Regulations R26.2 "In houses a drinking water tap should be located over the kitchen sink and be connected to the supply pipe. ....."
Drinking (Potable) water is a Fluid Category 1 defined as "Wholesome water supplied by a water undertaker and complying with the requirements of of regulations made under section 6.7 of the Water Industry Act 1991"
The change in temperature of the stored tank water could also change the category of the water from 1 (wholesome) to 2 (impaired aesthetic quality).
So you could go as far as saying that there is no wholesome water supply.
Water Regulations R26.2 "In houses a drinking water tap should be located over the kitchen sink and be connected to the supply pipe. ***.."
Thanks for this Steadyon.
Seems like such a fundamental mistake that has been made. Hopefully fixing this doesn't mean a big rip up jpb.
I will just add this.
There is a clause that states if it is not feasible to get a direct connection to the mains supply, a tank may be used.
The tank needs to be fit for purpose and regularly inspected/cleaned.
Reply to Kitchen Cold tap not supplied by cold mains? in the USA area at PlumbersForums.net
Sonya K
