Discuss Kitchen tap Connection to mains issue in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Adam tl
Hi, I am replacing a kitchen tap and have run into some trouble when connecting the flexi hot and cold pipes to the hot and cold mains pipes. The connection end of the flexi pipe from the tap is a15mm, however the mains pipe I need to connect to is a 12mm. What connector do I need to buy? So far have only found reducers and couplers with either the same female to female ends, and the same diameter ends.
Thank you,
Adam
Reply to Kitchen tap Connection to mains issue in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
