Discuss Kitchen tap mixter sudden stopped working in the USA area at PlumbersForums.net
Cold water side works but hot suddenly stopped working.
I’ve checked that there are no leaking pipes. Any idea? I got it installed 1 month ago. Is it down to a poor installation???
Update: the hot water issue seems to happen every week either afternoon Friday or Saturday? Sometimes it stops for a few hrs to half a day. It’s really puzzling me
Photos of the tap and pipe under the sink
do you have a presure drop at them times, as the taps look like they are the lift type,and that one may be sticking.
Thanks for responding. The pressure you are referring to is the boiler right? I’ve checked the screen. It doesn’t drop, or it’s not noticeable. Would you increase the pressure to test? Atm it’s at 1.5
no!!!!! its not the presure in the boiler , i mean your incomeing water presure to your cold tap, as if this drops at them times then your hot water presure will allso drop. at your tap and if the hot tap is sticking then it will poss not work.
Reply to Kitchen tap mixter sudden stopped working in the USA area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
