Discuss Knocking/Tapping Noise After Running Dishwasher in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I wonder if anyone could advise a possible cause of a consistent knocking/tapping noise from when the dishwasher seems to empty? The noise seems to continue for about 10 minutes after the dishwasher has finished its cycle. From my understanding It's seems to be coming from the soil stack.
We have an ongoing issue with the soil stack pipe being boxed in tightly and consequently when hot water is released it is expanding and knocking on a joist. My understanding though is this is further up the stack on first floor level as the new noise seems to be coming from much lower down as is audioible from the ground floor. The original issue was present from day 1 (new build property) surly the same issue wouldn't suddenly develop from a different outlet?
Any help or advice appreciated.
Try a hotter , cooler wash to test your theory ?
( the greens will have us using less hot on dishes ,but food is more greasy than clothes ! )
Reply to Knocking/Tapping Noise After Running Dishwasher in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud clicking/knocking sound that lasts about a minute, stops for 20-30 seconds and starts again. It seems to happen at night, starting in the evening...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
