Discuss Kw calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If you just want to convert KW to BTU or vice versa, then use this:
Convert BTU to kW - British thermal units conversion to kilowatts
As it says:
To convert BTU to kW simply multiply by 0.000293. To convert kW to BTU simply multiply by 3414.
That's like asking a checkout person in Asda how to make a crêpe suzette! You may be lucky and ask one who actually knows, but I wouldn't like to bet on it.Yeah it's the rad calculator I need as I get hugely different readings from the lads in the plumbers merchants
Reply to Kw calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
