Currently reading:
Landlord Gas Safety Checks
Discuss Landlord Gas Safety Checks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
twitchboy
Do you need your CCN1 and appliances to do landlord gas safety checks, or is your CCN1 enough?
Cheers
Re: Landlord Gas Sfety Checks
Depends what your inspecting. If there are appliances then you will need the relevant modules.
It depends on what appliances you are checking?
Are there any appliances that allow for just CCN1? I would have thought that if you're doing landlord safety checks on cookers and fires then you'd need those tickets but someone has told me different and says that you only need those tickets if you're servicing and repairing them. A 'check' he says is different.
Is he talking cobblers?
Cobblers he talks! Your need to know his the appliance works in order to check it's working properly and safely ? Otherwise why bother with ccn1? Surely an electrician could just do it?
you could do a tightness test!
but that is quite limiting.
boilers, cookers, fires to cover most situations
Next silly question.
You have your CCN1 and your ticket for cookers, fires and boilers. But you do not have your ticket for meters.
The home you are checking has a cooker, fire and boiler which you have, but you do not have your ticket for meters.
Can you do a landlord safety check without your ticket for meters? Other than being able to remove the meter, does not having your ticket for meters limit what you can do when carrying out a landlord safety check?
When asked to carry out a landlord gas safety check does this automatically mean that the appliances would be serviced during the check or would that need to be requested separately?
you are only checking if appliances working correctly and check for any defects on pipework etc. service is optional and has nothing to do with safety check
I suspect that's why some people think they don't need their appliance tickets for gas safety checks.
Would you still do spillage test and flue flow when doing a gas safety check?
If relevant to the appliance yes
you will learn all these questions during your ACS. Each appliance has its own checklist which you should follow in order to check if its working safely.
I'm happy with this at the moment Mas, there's nothing technical and, if anything, could be educational for Joe as to what they need checked.
It should teach twitchboy he needs new gas mates, cause the ones he has (outwith here) are scaring me, TBH some of the ones on here scare me too but that's for another thread
I am not a gas engineer but I do employ gas engineers who do this work.
So
I wanted to know the answer to this question too and it wasn't easy to find a reliable source for the definitive answer.
It was a teacher who told me same as what others have said in this thread.
So if there is a fire/ cooker you need to be qualified to work on those.
I think there is genuine ignorance on this particular question.
Or perhaps convenient ignorance. Because most of the time there is only a boiler in the property Many, many times I have heard of Landlord inspections being done and completely ignoring the cooker or fire, the engineer or employer had not anticipated that those appliances might be there, the job would take longer (but they are only charging pennies) andd the gas engineer does not have the right skills.
So
We had a limited skill engineer did a flue flow on a b/f and capped it off. He wasn't qualified but told lads in office he could do the cp12 as it only needed a smoke bomb. Bye bye muppet.
Was this in a training centre or on an actual job?
Reply to Landlord Gas Safety Checks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
