Discuss Landlords cert....again in the Plumbing Jobs | The Job-board area at PlumbersForums.net
clarky101
Hi, done a Landlords cert on a 3 year old Logic Plus Combi which though out so much co that my fga went off the scale. Told landlord, capped gas, attached warning notice, wrote all down on cert , landlord getting Ideal in as its in warranty .......now is the cert chargeable ? Or do I charge twice for a cert after Ideal have been in? Looking forward for your answers......
Send it as llgsc isn't a pass or fail
When I take my van off for MOT, if I leave the premises and return for a retest they have to do a full retest and so are entitled to recharge in full. Never taken my van away, but if I did and they did charge me twice, so be it, and I'd still take my van there. I think the parallel is obvious.
What are you all talking about?
The first visit - the OP has identified faults and acted accordingly . So far so good.
All that should happen is to write out the cert and get paid.
Ideal will visit. They will rectify and do the relevant tests.
End off.
There is no requirement for a 2nd visit or 2nd cert.
All assuming Ideal accept that it is a warranty issue.
Ideal will rectify yes, but won’t carry out gas cert. that the landlord needs. OP failed first one so will need to come out again to sign off for the landlord the second time.
Sure I heard somewhere that as long as the issue highlighted on the cert is rectified and paperwork left to confirm this. Another cert is not needed. As above though. If they wanted a cert that said it was safe it would be chargeable
Ideal will warrenty there work eg check it's within limits and should leave a report
Fair point. further question (possibly not for this forum!!). what if the OP took initial CO reading and ratio was sky high with immediate fail. would Ideal carry out full check following this, including safety devices, negating the need for the follow up check by OP
They would have to, to confirm it's working and within manufacturer spec
GC. No. you are wrong, mate. But you are not alone.
It did not "fail" the first one. There is no such thing as a "fail" in that context. The requirement os for a cert to be issued as a "snapshot" of the installation at the time of testing. The cert IS issued as it stands. You categorise your findings, and you either do the remedials, or the punter goes elsewhere. End off.
If Ideal attend, and agree to rectify, they have to comply with 26.9, so will be left safe.
Obviously, if the punter wants a "clean" cert, he must then pay for it - but it has to be done from scratch, as that will be the snapshot at the time of that inspection.
Who suggested they should?
I think he was referring to the original question of should I charge for the first visit or only charge on return visit?
That's how I read it.
Also on the MOT situation some (most) garages do a free retest which could be why some people ask the original question?
I would say charge for 1st and charge for each subsequent visit. Just tell the landlord I am sorry but it's taking up a slot I my diary where I could be earning money elsewhere.
Reply to Landlords cert....again in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be...
3K
Hi, I have an ideal logic plus combi boiler that has been working fine for all of winter. With the recent storms when the wind speed starts...
3K
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached...
2K
Very short version. Im a sole trader of only 10 months, but an experieced Plumber of 30 years. Installed a bathroom for a customer, they wanted me...
3K
Apologies if this has been answered elsewhere, but my family and I are starting to crack. I'll start at the beginning, and maybe someone will see...
3K
