Discuss Lead rising water main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Steve Macca
Hi guys,
I'm part way through buying a house as a buy to let investment. We had a survey done on the property and it said the property still has its original rising water main, which is made of lead.
I understand these are quite expensive to get replaced. What would a replacement involve? Would they have to dig under the house to get to the main pipe on the road? Could someone give me a rough estimate of how much this might cost?
Would it be ok the leave the lead piping in or do they really need to be changed?
Cheers!
Steve
Change it whilst the place is empty. It's bound to fail when you've got tenants in and you'll be in a rush and end up paying through the nose.
price of a trench and some blue mdpe and fittings, its the trench that costs
You could get a 'Mole' to tunnel the new pipe in for you. No trenching that way. Get a quote from a specialist contractor. There's a bloke round my way doing it. See his van & trailer every where.
Reply to Lead rising water main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
Hi there, Have bought an old house and am having the old lead water mains pipe replaced and a new stopcock location/piping installed after massively high readings from water testing by the water company. Also buying new plastic water tank to start afresh so to speak. Pipework/joinery looks to...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better way to go. Just after some advice and rough costs involved, is it worth getting a pressurised system installed and a new boiler and oil pump? Heating...
Hi there I’m 10 weeks pregnant and found out we have some steel galvanised pipes with corrosion which was causing our tap water to run discoloured for a few seconds when not used for a couple of days. I understand this is from rust but was told lead could also be leaking into our water because...
