Discuss Leak in bath sealant in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi lads,
So I think these gaps in the bath sealant (we use the bath for showers) is responsible for a leak that occurs in one of the rooms downstairs.
I have two questions: a) there's a huge gap at the corner of the bath, which probably needs sealing too and b) do I have to remove the old sealant in that area or can I just seal over it?
Much appreciated.
[automerge]1571864213[/automerge]
*Sorry for that picture being ginormous, but at least you can see it well!
It needs to be removed completely and replaced with a quality sanitary silicone there's no easy way a sharp utility knife the sort with snap off blades to cut through the old silicone and scrape away the remainder untill your happy, fill the bath with water apply the silicone taking care not to over fill the joint , it's better to make sure the cavity is filled between the bath and the tile you can always add some more then smooth off with a smoothing tool some soapy water will help you so the silicone doesn't stick to everything plenty of kitchen roll and wipes to aid cleaning up, one tip don't apply the silicone in one go do each end then half the long length then the rest leave for 24 hours to cure , you are looking to achieve something like this . Kop
[automerge]1571893040[/automerge]
Reply to Leak in bath sealant in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Just moved into a house and in process of renewing sealant around the shower cubicle. Feel free to skip to the bottom to get the question...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and...
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from...
