K
KatyLH
I have recently had a new bath suite fitted since which time the bath has been leaking and the plumber that fitted it has said there is nothing more he can do
the bath is leaking from the plug hole. It leaks when the plug is in and when the bath is being drained or the shower is being used.
I think it must be something to do with weight as it doesn't elk when my youngest daughter is in the bath however with my older daughter myself or my husband it does.
the plumber said it was because the bath had too much flex in it so suggested we put bricks under the bath to hold the weight, that hasn't worked!
He then came and sealed the rubber things (sorry don't know what they are called) from the plug hole to the waste pipe. This still hasn't worked. Now he says he an do nothing else! Please help.
thank you
thank you
