Discuss Leaking Swivel Bath Screen in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I recently detected some leaks from my bathroom. Part of the issue was water escaping from the bath screen.
A plumber refitted and sealed the bath and screen. Unfortunately, the water is still escaping near the base of the hinge of the shower screen.
I have attached a picture of the base of the screen. Is there a piece missing from the screen?
The second photo shows that it is possible to push the base up and more flush with screen but the screen would be angled in the open position that way.
Any advice would be greatly appreciated.
I would say the hump chrome bit is supposed to turn ?
The 'upside-down vee' in the grey plastic, and the corresponding hump in the lower part are there as part of the design, to make the screen lower as it moves into position along the side of the bath. Positioning the whole thing on the wall is critical to get the seal along the bottom of the door (which is missing in the picture) to touch the edge of the bath to seal properly all along its length.
I would have expected the hump bit to be hidden by the wall strip - no that's not right, sorry. It needs to be in the right place to engage when the screen is at right angles to the wall. As per Shaun, has the bottom bit moved round from where it should be?
The bottom door seal can be crafted to fill the little gap by the hinge as best as can be done.
The vee is a cam to lift the shower screen up when you open the screen, this is to avoid damaging the seal and to allow it to work on baths with a small lip.
The screen should be fitted in line with the inner edge of the bath, most people fit them too far out onto the bath edge and then they leak.
Reply to Leaking Swivel Bath Screen in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Evening. I purchased a house 1.5yrs ago and the hinged shower screen has started to leak. I’ve tried several new seals and none seem to work. As...
Hi all, I recently bought a house. The shower screen has a small leak, which can result in water ending up on the bathroom floor (quite a lot of...
I'm looking for a single-piece shower screen to replace the 4 panel folding (got black mould on the rubber parts). Something simple like this...
6K
I have an open vented central heating system with a hot water tank. Both heating and hot water circuits have a motorised valve controlled by a...
4K
Odatmi
O
