Discuss Least Bulky Plastic Fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Was going to say that, tectite are tiny compared to the plastic ones.The copper type ones are small
Just to clarify Cailean's detailed reply; Conex Cuprofit are only for copper pipes.Tectite Sprint or Conex Cuprofit are the least bulky. The Tectite fittings work with PEX if you use the correct liners/inserts. However I recently had one leak on me, which is the first out of many that I've used and I'd thoroughly test your system before putting your floorboards back down. Tectite are non demountable and are permanent, Cuprofit are demountable with their special tool.
You can also use compression fittings with plastic pipe, but use copper olives, not brass olives.
Pegler Yorkshire - Sprint
Reply to Least Bulky Plastic Fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
