Discuss Life span of flexible tap connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have fitted hundreds of flexies. Failures.....0.
Been in the game for 34 years but thanks to a few people on here that don't like flexies, any potential customer that looks at this forum will consider anybody that dares to use a flexie as a cowboy.
Yeehaa boys and girls, back to the ranch I guess.
Only had a two blow. Same job. 1m long 15mm plastic braded ones. Brading long gone ballon inning rubber inners. Told custard, ignored me, 10pm on a Sunday night that same week!!!! Help? Flexi on heating is insane!
We have just changed loads of them in a hospital. They have their place but do harbour legionella.
Lazy plumbing IMHO.
I've seen a few flexis fail, mainly though due to what I suspect is frost damage (caravans get bloody cold over winter). I always use copper tails where possible because they just seem an easier safer bet. I've fitted a few flexis but don't like them.
I recently replaced a burst flexi that failed because bleach based cleaning products had got past the tap to basin seal and corroded the stainless steel braiding. That, mind you was the first that I have come accross. However, reading this thread has given me pause for thought about changing to copper.
Diy'er here but in commercial construction. Early 90's office block had radiant heated ceiling panels around the perimeter with flexi connectors. One fateful night (luckily before handover) several burst and the blame game started between the panel installers and the commissioning engineers. A forensic plumbing specialist (yes, they exist) called in by our insurers determined that whilst there was evidence of overpressure on the system the hoses were duff. The four or five that went showed twisting on install but lots had poor connection between braid and end ferrules. All replaced and the office block is still using the same system. I have had one go at home which had poor braid connection in the same place. I am now worried about the buggers buried in the back to wall wc's!
Hello All,
Personally I would never use these Flexi`s for 2 main reasons:
The internal bore on some of them is only about 8 - 10mm and even on the `better ones` it is not much more than 10mm - I would not want the large reduction in water flow volume that this causes compared to the flow from 15mm Copper tube.
Even with Monobloc Taps where the tap tails obviously reduce the water flow volume I would still connect with 15mm Copper tube obviously reducing down on the tails - it is a much better job.
Also - without wanting to annoy any of our Members - I don`t rate ANY of these `Flexi`s` as a `professional` fitting / product because I have no doubt that even if they do last over 5 years - they are very unlikely to last 20 years.
Members might state that Households would normally be changing their Bathrooms / Kitchen Sinks / even just Taps more frequently than every 20 years - that is probably true for most Homes but not all.
I would want ALL Pipework that I install to be guaranteed to last at least that amount of time - with no `possible weaknesses` in the pipework - so that there is NO chance that one of these `DIY products` would fail and flood out the property !
As I mentioned I am not trying to annoy those Members who do use Flexi`s - each to their own regarding attitude to subjects like this and their opinions about `Professionalism`.
Chris
Reply to Life span of flexible tap connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
