Discuss Limescale build up on Cylinder hard water area in the Central Heating Forum area at PlumbersForums.net
Hi I'm going to have a cylinder replaced because its failing there seems to be a lot of limescale build up i have heard of inhibitors liquid form but also heard you get electronic ones that emit a frequency ? are they hard to fit and do they work
Cheers
You can get inline or wrap around scale fighters for around £30-£50
They help but dont stop limescale.
A water softener is usually the heat solution but are expensive.
You'll need a g3 qualified plumber to fit the new one and they'll know what's needed in your water hardness area.
Reply to Limescale build up on Cylinder hard water area in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
