Discuss Limited Hot water in cold weather in the Central Heating Forum area at PlumbersForums.net
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external wall) which for the most part seems to provide excellent hot water. The central heating also works fine - though sometimes I think the radiuators could be hotter, then on other occasions they are uncomofortable to touch.
Normally the whole system works fine but during cold spells (overnight <=0C) I get very limited hot before the water starts to get cooler. What water I do get starts off fine and hot, runs for maybe 5 minutes then starts to cool down.
If I run a bath, I get maybe 6" before it starts to go cold. But the boiler will produce more hot water quite quickly so a soak in the bath is possible with constant topping up
It behaves as if only part of the HW tank is being heated but I cant see why that should have anything to do with temperature
https://community.NoLinkingToThis/styles/default/xenforo/clear.png
Any suggestions as to why this might be?
One of those pumps (secondary recirc pump) recirculates the water in the cylinder to your hot taps etc, and back to the cylinder, if that's running continuously and is not on a timer or pipestat then it will quickly dissipate heat through the pipe work.
The other one circulates the system (primary) HW from the boiler through a coil in the cylinder to give DHW.
Is there a 3 port mid position valve after this pump to give single zone CH or DHW or both or is there a number of motorised valves after the pump?.
one pushes hot water round the CH system and the other, I presume, to the taps
The boiler pump is clear.
I thought the other pump circulated water thourh the radiators
THe Cylinder is described as Flowmaster Mains pressure System so I presume this (the mains) provided tap pressure
Both pumps are controlled by external sensors. I presume CH is by the main thermostat in the hallway and Boiler via the boiler thermostat (the one with the arrow) Ive attached a picture (Please dont give me hard time about the wiring!!!)
Can you see which pump the cylinder thermostat is wired to, when this pump is running feel the return from the cylinder coil?? and see if its hot, cool or cold.
The red (grundfos?) pump seems to be the one circulating through the coil.
Cylinder thermostat is not wired to either pump. It goes into the collection of wires on the wall. There it must go either to the hall thermostat or to the boiler. My best guess is the boiler . Ive done a diagram of the wiring which might help
What you refer to as a thermostat looks more like a immersion heater to me, a cylinder stat usually has a dial on it that you can set, usually to 60C.
Thermal store john
A thermal store so maybe check that the cylinder stat is starting up the boiler once there is either a DHW demand or a CH demand, I think some have a flow switch on the DHW outlet to start the boiler immediately, once the store is used up then the DHW output is probably determined by the boiler output and flow temperature, a 30 kw boiler might give a continuous DHW flow rate of ~ 10LPM at 50C from mains at a now 7C. In cold weather the CH will also have a effect although one might think that the rad temperatures would start falling before affecting the DHW temperature. If the circulating flowrate through the store/boiler is too low for whatever reason then the boiler will still give its target flow temperature but the boiler could be running well below its rated output and the store temperature and DHW temperature will fall depending on the DHW demand so maybe thats a reason for the 5 minute run of DHW?. Possibly a circ pump problem?, the only sure way of checking the boiler output is to take the gas consumption over say 3 minutes, its easy to calculate the boiler output then.
Reply to Limited Hot water in cold weather in the Central Heating Forum area at PlumbersForums.net
