Discuss Loading unit flow rate Vs simultaneous use flow rate in the USA area at PlumbersForums.net
I believe it's because they assume you will rarely if ever have all the outlets running at full blast all at the same time.
A bit like how sparkies can sometimes get away with using a smaller cable for a given number of socket because they don't need to account for a 3 bar electric fire running on every socket on a ring even though it's theoretically possible to do so.
There's a word for that but it totally escapes me right now.
Reply to Loading unit flow rate Vs simultaneous use flow rate in the USA area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
