Discuss Loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
Hi Friends
Received my free 12m sample if Loctite 55 today.
Has anyone used it? Any good? Worth buying?
Rct
Loctite 55 is great stuff. Never had a leak with it. I'll still keep my rolls of ptfe though!
I'll buy some then. It looks like teeth floss!! Just wrap it around and hey presto? Thanks all
Use it exclusively for water and gas, still have to keep ptfe for oil though.
Yeah, just a few wraps and there you go. Apparently allows a quarter of back turn without leaking but if I have to back off a fitting I will always completely undo it and start again (as you would with ptfe) as for ptfe being in the past, I don't think that's necessarily true. It will always have a place in most plumbers vans. It's 20p a roll, and we all know that PTFE stands for:
Plumbers Tape For Everything.
Leaking o ring on an oil filter?
wrap in ptfe....
Never used it, so can someone tell me all about it and how you use it please.
its nylon 'string' with some sealant on it, use in same way as ptfe on threaded joints. It s very good.
Reply to Loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
