Discuss Loctite 577 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Last Plumber
Subscribed
Loctite 577, What are you paying.
Have you used it a lot and what do you think of it ?
Has anyone used Loctite 518 for anything ?
Just curious !
I use 577 for making valves into chrome towel rails and bib taps into back plates. Not had any leaks. But I'm not confident enough to use it for anthing hidden.
Do you trust me if yes your fine it's the only thing I use now for small stuff (2" and below) hasn't had a drip yep
Sounds impressive.
I take it you've thrown the boss white and hemp out then ?
Nope still on the van always carry a Hank of it :)
For steel and the big stuff
Good man, same here, Don't let the old habits die out.
Can't beat the smell it gives your van on a hot summers day mmmmmm!
Cleans your fingers as well (boss white)
Use 577 loads and had no issues, e bay is the cheapest place i've found. I buy the smaller pots then top them up from the larger ones.
Reply to Loctite 577 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
