Discuss Long Sink/dishwasher waste pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Morning all,
A diy'er here. I'm installing a new kitchen in a room on the opposite side of the house and need run the sink and dishwasher waste under the floor to the opposite side and go out where the existing kitchen is, around 9m. The driveway and garage are outside the wall in the new location which is why want to avoid a lot of work and disruption on that side.
It's a suspended timber floor and the cavity is more than deep enough for the 25mm drop per metre (is that enough over that distance?). I'll need to put two 45 degree bends in.
As long as the pipe is fully supported, do I need to make any more considerations?
Would recommend 50mm and venting sink end as your over the max distance
Thats more than double the recommended pipe run length so get it large as possible in diameter even if it over a short distance , it must be vented and allow rodding access in case of future blockages . Kop
Thanks both for the replies.
My existing sink waste pipes aren't connecting directly into a main waste pipe like the 110mm ones, they are above an old style external open grate and just funnel into that, do I still need a vent in this instance?
I was just going to run 50mm pipe, is that enough?
Reply to Long Sink/dishwasher waste pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Hi all, Just in process of relocating kitchen & utility to other side of house but have a question re venting requirements. I intend to connect...
Joeab88
J
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
Attached is a ground floor picture of the soil pipe in our home. There was originally a toilet which has now been permanently capped off and you...
1K
Evening all. Not sure if this is the most appropriate place to post this in the forum, happy to move if not. I'm looking for a metallic 32mm...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
