Discuss Looking for a gas safe engineer to install 28mm gas pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coldboiler
I'm looking for a gas safe registered engineer (previously Corgi registered) to remove the existing gas pipe and install a 28mm gas pipe from the meter to a new boiler and tee to a cooker and fire. I am not asking for it to be connected to the boiler, just to end where the boiler will be.
I need someone with experience and the confidence to tackle a 28mm pipe that needs to go through 2 walls and partly under a concrete floor. The pipe work needs to be sleeved in 35mm copper pipe (provided for going through walls). The pipework is around 25-30 feet long.
I have the necessary copper pipes and a number of Yorkshire fittings, tees, elbows etc (pre soldered) on site.
I am prepared to pay £350 -£400 for labour.
I am located in east London, Leyton.
If you are interested please contact me. Preferably with some photos of previous work.
I am also interested in hearing from anyone with experience of Tracpipe and iron pipe.
Thanks Coldboiler
Anyone interested in this opportunity please pm the OP direct.
Reply to Looking for a gas safe engineer to install 28mm gas pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
