Discuss Loud whooshing noise from combi boiler when turning on hot tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
saleman
Dear plumbers/experts
I'm getting a loud whooshing noise from my Ravenheat combi boiler when opening hot tap. It's particularly bad as soon as I open the tap (sink and/or shower). Once hot water is flowing, the sound seems to stop. However, we've noticed a slight fluctuation in temperature in the hot water and when it gets colder (only for a few seconds) the whooshing noise re-occurs - only much softer sound. I've bled all rads so there is no apparent air lock in the heating system - which works fine. The only problem is with the hot water.
This has been going on since I replaced an old radiator in the hall way. I had to drain the system. I refilled slowly, bled rads, and topped up with inhibitor. Heating working fine.
Any advise would be greatly appreciated.
Saleman
Reply to Loud whooshing noise from combi boiler when turning on hot tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
