Discuss Low hot water pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Jason brad
I've had a new Firebird combi oil boiler fitted and the hot water pressure is low( in fact it's terrible)..the cold water pressure is good and I can't find any leaks and loose no pressure. Please help. Thanks alot
The hot water pressure is terrible?, do you mean the hot flow rate is very poor but the flow rate is OK but too cold if a hot tap is opened fully?
What is the Firebird power output.
Should be the same as the mains pressure
20 kw output. Thanks
20kw should give a hot tap temperature of 40C at a flow rate of 14LPM or 7LPM at 60C, can you just open a hot tap fully and see how long it takes to fill a 2 litre container or any sized container and compare this with the time taken to fill the same container from a cold tap.
Reply to Low hot water pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
