Discuss Low hot water pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals.
We've been in our house for over 3 years now, when we moved in the hot water pressure was pretty good (confirmed by a retired plumber family friend). Over time the pressure has got worse and worse and we're now at the point where by its getting bad.
We have a 200L hot water tank in the bedroom and this is fed from an expansion vessel in the roof. I checked the pressure yesterday and it was around 0.5 bar and I was not able to re pressurise it. I took the vessel off and to the local plumbing shop where they said it was dead. I purchased a new one and fitted it (no leaks) but the hot water pressure is still not any better. I checked the new unit too and it reads 3 bar (pre installed at that level).
I'm thinking it could be a build up of sediment as we live in a hard water area, does anyone know of anything else I can try before I call in the big guns?
Unless you are a G3-qualified plumber, you should not be making repairs to an unvented HW system. Your home insurance probably requires an annual check and no DIY repairs in its terms and conditions.
Has the system been inspected annually by a qualified person (normally the same on who services the boiler)? If not, get it serviced and, if it's the problem I have in mind, it'll be an easy fix for someone who knows what they are doing.
Reply to Low hot water pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
