Discuss Lukewarm water problem with Veissmann v 50 gas boiler in the Central Heating Forum area at PlumbersForums.net
Hi all, thanks for adding me.
My Veissmann v50 combi gas boiler has recently started to supply only lukewarm water to the bathroom above it. This is about 3 metres away, so quite a short pipe run. It supplies hot water fine to the kitchen taps, which are about 1 metre away. It also supplies very hot water to the central heating system, with no problems. The boiler is about 6 years old. I have made sure that the boiler pressure is okay. Can anyone suggest a solution?
bath flow is normally faster flow, not pressure don"t get mixed up like a lot of folk do.
try slowing the flow down , and see if that sorts it
Ok thanks. I meant that the boiler pressure is okay, I realise that this isn't the same as the pressure to the taps. A heating engineer has said that I need a new boiler, what do you think?
Reply to Lukewarm water problem with Veissmann v 50 gas boiler in the Central Heating Forum area at PlumbersForums.net
