Discuss Magnetic Filter........ in the Central Heating Forum area at PlumbersForums.net
John.g
Subscribed
Saw this briefly, installed on a Glowworm boiler, what is the orange graduated knob for?, the arrow above it is pointing downwards but if the M.filter is on the return then the flow will be upwards.
I learn something new every day, if you click on the image (post #1) then right click to bring up the menu then select "image wih google" (google lens) it identifies it as a BI-World M.Filter, the orange knob is a Servicing Date Wheel.
As it’s 12 graduations and looks a “dumb” knob, I’d guess it’s used to indicate which month service is due- as simple as that !!
Reply to Magnetic Filter........ in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
PSxxxxxx
