Discuss main incomer water pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
thecount101
hi , i know that we could not fit pumps to incoming water supplies--but i am led to believe that we can now! does anybody know what or if this is true?
i desperately need to boost our incoming pressure-- please help
no its illegal to fit a pump to mains
why do you need to boost your mains supply ?
You can boost the pressure by interposing a 'break-tank' between mains supply and pump. This way you are not pumping mains water, but the water in a tank that is being filled from the mains via an air gap.
Maybe this is what markfxy's 'grundfoss home booster system' does?
Reply to main incomer water pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
