Discuss mains water pipe be run through an integral garage? in the USA area at PlumbersForums.net
Can a mains water pipe be run through an integral garage? It's to feed a washing machine used 2-3 times a week. Is there a risk of the pipes freezing?
Fine but would insulated it decently eg 19mm and would install a drain off and stop tap so you can isolate and drain when we have really bad frost
Reply to mains water pipe be run through an integral garage? in the USA area at PlumbersForums.net
I have moved our washing machine into the garage but there isn’t a drain for the waste pipe. The attached image is of the waste pipe with the...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone...
Hi, I have just moved the washing machine into the garage and it will not drain. I wonder if it's something to do with the way I have installed...
1K
R
Hi there, Please excuse my lack of knowledge on this, my plumbing knowledge is very limited. I have a cold water feed going into cistern with...
