Discuss Making good to wall behind rads when replacing rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
up to now I've left the wall as is when I replace a rad.
What say you lot?
I'm not going to lie, I've been doing this 11 years and have never replaced a radiator :D
What do you mean jay painting the wall ? Or do you mean more indepth like plastering and filling ?
Only if cus asks for plastering or painting
But if different holes fill the old ones with filler
Never done that either.. might start offering to make good the walls and charge accordingly ;)
Normally just take them of for customers to paint or get re plastered
I try to remove any old wallpaper where the old rad was and maybe fill any original rawplug holes etc.
Ok.. I'll start filling old holes.. but the rest is up to the custard
I have only ever taken them off for customers to decorate, then they call me to put them back on. Or when they want new ones. Nobody normally looks down the back of radiators apart from heating engineers.:DI have about 3000 wax crayons, 10 key rings, 1 broken pen and 30 different socks on the van from changing rads:p:p:p
Yes mate filled holes , plastering , painting , even wallpapering all chargeable heres one to make you smile could not believe what was behind this rad
Yes mate break your days work into a hourly rate and charge accordingly if it take 2 hours to make good then charge 2 hours at your rate saves you going back again behind a painter and decorator cheers kop
Wonder way the van is untidy :p:p
Reply to Making good to wall behind rads when replacing rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
