Discuss Mastic turning to toothpaste. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jackplumb
Has anyone had problems with mastic turning to a toothpaste like substance? I'm thinking that the sealant was attacked by bleach before it had fully cured. Any ideas?
Had it once before when I bought a load of cheap mastic. Never again!
Was it neutral as opposed to acetoxy?
Sounds to me like a bad tube (out of date, been hit with frost or just a bad tube)
Reply to Mastic turning to toothpaste. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is...
Total plumbing-tiling novice. Our bathroom has been tiled. What should we use where the walls meet and where the tiles meet the ceiling - mastic...
Hi All As you can see from the attached pix, the flow control knob on my Bristan shower has broken. It was installed before I bought the house...
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the...
