Discuss Megaflo auto air valve leaking again in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I noticed some months ago that my Megaflo auto air valve was leaking so I replaced it, the replacement valve has also started to leak with a waxy residue. I recall that the original AAV had a black lid and the replacement has a brass lid, does it matter which version is fitted? Can I permanently remove the AAV and bleed the system elsewhere?
What brand is it and is it specced correctly for your heating system? Pegler Prestex ones have a five year warranty IIRC. OTOH, if it's a knock off from eBay you get what you pay for.
IME, this type of AAV has never been noted for reliability. If they're not in an easily monitored position it's a good idea to fit them with an isolating valve so you can leave them working for a few days/weeks after draining and refilling, etc. and then shut them off for the other 99% of the time that they are not needed.
The condition of the system water maybe should be looked at as well, I prefer the manual "thumbscrew" type air vent that can be opened occasionally.
If your cylinder is heated by solar thermal you need a specific aav that is rated above 100 deg C, a “normal” one will fail very quickly .
Reply to Megaflo auto air valve leaking again in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
The pipework around the hot water tank in the airing cupboard has developed several leaks after a chemical flush. It's an open vented system...
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
