Discuss Megaflo water tank- no hot water in the The Welcome Wagon :) area at PlumbersForums.net
Hi everyone,
The water in the apartment is not heating up hot, it’s either freezing cold or lukewarm. The red and yellow lights on the grundefos pump suggest in the manual that there’s a blockage. We’ve tried resetting the tank and the grundefos but to our dismay, we thought after doing all this yesterday the tank may heat up overnight but sadly not :(
The pipe itself attached to the grundefos is hot so unsure where the problem lies
Pressure in the system should be above 1 bar ?
Maybe pump stuck Turn the programmer to off eg heating and hot water both off there’s a hole in the centre of the pump that deep down in side you will see a pozi screw when there’s no lights on the pump insert a screwdriver down and onto this pozi and push it towards the cylinder and twist clockwise a full turn
Reply to Megaflo water tank- no hot water in the The Welcome Wagon :) area at PlumbersForums.net
