peter.beasley1@
Hi all
I had a dual element (top element always on and the bottom element on economy 7) Megaflow fitted a couple of years ago and generally it is pretty good.
However, I have already replaced the bottom thermostat twice and now it is playing up again. If I push a small screwdriver into the reset and then turn the temperature setting down and back up, it works for one night but then doesn't work the next night. It is difficult to test as it only has power between midnight and 7:00am
Any ideas why the top element seems to carry on fine while the bottom one keeps failing?
I can't believe that I have bought 2 dodgy elements as they were both Heatrea Sadia parts.
I have wondered about using a standard thermostat from a normal immersion as they are cheaper and don't have a reset. Does anybody know if this will work?
