Discuss MEXICO SUPER 3 CF 100 spares ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, has anyone got a broken MEXICO SUPER 3 CF 100, or spares ?
I'd like to buy the combustion chamber as mine has developed a hole,
Thank you !
Okayyyy
How do you know this?
You cant be sticking second hand parts in a boiler, surely?
Also; if you engineer has said it needs one, they're fitting it etc so perhaps go with their recommendations as to where get one from?
I'm not getting good vibes from this thread lol
Help us help you. Hopefully it's all above board. :)
Thank you !
Its very rare to find anybody that deals in random boiler spare parts basically as it is a legally restricted market...GSR etc...Ignite Heat Spares do re manufacture many parts
for older boilers but only MES parts. Ok Dan ....centralheatking
clutcjing at straws arent most parts obsolete for this boiler its also conventional flue so not particulary fuel efficient. even if you can get one the cost to change wont be cheap these say they have one but as i said not cheap DHS Spares, buy now at dhsspares.co.uk £700.00
And there's no nearer external wall?
You have a boiler 12 meters deep into a building..?
Don't think I've ever seen that.
That said I'm not a plumber!
if you want to use the flue there are some condensing boilers that do viessmann are one. i assume if its 12 metres to chimney top its in the basement so unless the basement is totally below ground then you should be able to use an outside wall
Viessmann do a glue kit that allows you upto 12.5m of chimney so aslong as it’s less than that your fine
100 series is the mid range
200 series it the best of the best
cheers guys, yes the boiler is in the cellar without an external wall, and the current flue goes into the chimney from the ground floor. The boiler is next to the HW, CH and U/F heating inputs so can't really be moved.
Thanks for the tip about the 12.5m Viessmann flue kit, it must have a large fan.
But you can probably see why it's much easier to replace the combustion chamber.
OR (and please be gentle with responses!) the hole in it is 8mm - could a steel plate be welded onto it ?
If you already have 1 hole in the combustion chamber, how many more are on their way.
When things like that start to happen it really is time to replace the boiler - as difficult as it may seem.
but is it all below ground
Reply to MEXICO SUPER 3 CF 100 spares ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
