Discuss Mira Excel post 1996 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gjbalsdon
Hi
I have a Mira Excel Post 1996 mixer shower. It has been in our house for over 4 years.
Over the course of the four years, we have noticed that sometimes the shower pressure is sometimes lower than normal and sometimes the shower has been stiff to switch on.
Today, my OH had a shower today and I went to get in and nothing, no water. I tightened the inside screw as I thought it was loose, shower switched on and it was stone cold. So I switched on and off again and the knob just turned and no water. It was as if the teeth had warn inside.
Opened tonight and teeth on both the knob and the black mixer cartridge appear fine, although two black clips broke off.
Tried manually turning the cartridge and still no water.
My thoughts are that the cartdridge has gone, but as we have an unvented system, I am concerned that it could also be the shower pump, but how can i tell?
You have had a great life out of the product if it is 96 (15 years)
If you phone Mira, the technical team is fab. They will give you the part details. And if you did want to upgrade. They will give you an easy bolt on replacement
Sent from my iPhone using Tapatalk
Reply to Mira Excel post 1996 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
