Discuss Mira shower head replacement in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Mira shower head.
Does anyone know anything about this shower head (I will post pics)
Its gotten a bit dishevelled, does it come apart easily & then just unscrew to replace with a different one ?
It’s a Mira excel shower head
The back comes off eg splits in the middle you can see a line then there’s two screws that hold it onto the wall etc
Your left with a 15mm pipe
Thank you Shaun.
Don't suppose you know anywhere i could get an exact replacement, I'm being told its long disconnected.
Yes I managed to get one around 7 years ago but the was old stock and cost around £200 but the client wanted the same
Best look for a moder equivalent that fits on 15mm pipe
Reply to Mira shower head replacement in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
