Discuss Mira Sprint Multi Fit Shower 9.5K - water flow has stopped mid-shower in the USA area at PlumbersForums.net
I have a 3 year old shower and the water has stopped flowing through yesterday, mid shower.
The RCD has not tripped.
The pull chord in the bathroom is on and the light is showing.
The on light is green on the shower.
I tested the on switch on the shower itself and it is definitely clicking in.
I have also tried without the shower hose attached.
The cold water feed is working as far as I can tell as it is coming from the pipes in the house and there is no loss of water elsewhere.
Is there a trip or reset switch in the shower itself?
Thanks,
Claire
Inlet filter possibly blocked if there's not enough flow through the heat exchanger it will shut down get this cleaned out is your first job ?? Kop
I have taken the cover off but the pipe is not coming away from the connector. The back of the shower is behind the pipes at the bottom so there is very little movement.
Have you undone the compression fittings when the water is off ?
Reply to Mira Sprint Multi Fit Shower 9.5K - water flow has stopped mid-shower in the USA area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
