Discuss Mira Vigour thermostatic shower needs new brushes. in the DIY Plumbing Forum area at PlumbersForums.net
Hi. Our Mira Vigour thermostatic shower is starting to make a whining noise. It sounds very familiar! Eight years ago I ignored it and ended up having to replace the entire unit. Older and wiser (courtesy of the internet) I realise (now) that it needs new brushes; I've had the cover off and can see the start of the 'blackening'. I've searched the internet for instructions on how to remove the motor so I can change the brushes, but can't find anything. In order to avoid the wrath of my (potentially shower deprived) family, can anyone steer me towards an idiot guide on how to remove the motor? Cheers.
Brushes not a serviceable part. Need to replace pump/motor assembly. Over 100 notes plus delivery. Might be worth swapping the whole shower and getting a full warranty on the lot.
I would buy a new shower and swap them over immediately.
Then play around with the old one to your hearts content, getting it ready to swap back in when the new one fails- that way you’ve got about eight years to sort it out and the family pressure is off!
Brilliant, thanks. Good advice from both - Not much difference between a replacement pump and the entire unit. Annoying because I'm seeing what looks like the same motor on a youtube clip having its brushes changed for around £10 !! View: https://www.youtube.com/watch?v=rT0M5j99jeY
At least I don't feel so bad about not trying to repair the last one!
On second thoughts, however....
If you can buy a replacement motor.... Mira pump motor assembly | Mira 453.03 | National Shower Spares - https://www.showerspares.com/search/mira_pump_motor_assembly_453.03/
And these guys are selling these brushes for a Mira Vigour motor for £9.99 Thermostatic....https://www.mrcarbonbrush.com/Mira_Essentials_Shower/p2644628_14008552.aspx
And if this guy is showing me how to replace the brushes in the same motor... Power Showers | Mira - https://www.showerdoc.com/default.aspx?id=654&n=654&cid=0&rid=0&catid=0&lid=1&range=9&cty=1554&pid=49197
Then I am back to my original question...does anyone have a guide to removing the motor?
Reply to Mira Vigour thermostatic shower needs new brushes. in the DIY Plumbing Forum area at PlumbersForums.net
J
I have an existing shower which I've removed and exposed the two pipes from the wall. If I was taking a guess they're around 2cm ish in diameter. I have the Mira shower here is the instruction guide...
JamiePattison
J
Hi learned friends. A "plumber" has installed a shower for my daughter. However it doesnt look right. This part circled isnt on any pictures I've found of the shower on the internet. It looks like a hex key may fit the inside? The picture on the right is how it should look. I've no idea why...
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming through the bedroom wall from the bathroom on the other side of the wall. The shower is over the bath and the bathroom walls are tiled around three sides of...
2K
Objective: I have an existing s-plan plus (see below for details) heating and hot water system, with 2 independent heating zones. There is a separate programmer and a simple room thermostat for zone 1 and programmable thermostat for zone 2. I have purchased the Drayton Wiser 3 zone kit and...
3K
I've tried to email Honeywell, but their web address is playing up and they aren't receiving. Unfortunately Honeywell is extremely poor at providing explanations even when I found the firm's online explanatory PDF that tried to explain what Honeywell means. Anyone had an answer that answers...
4K
