Discuss Mixer shower extension - installed too low, needs to be higher in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beesley121
Hi guys
doing a job for a builder, he's managed to install the bracket for the mixer shower too low and I didn't realise till I've just gone to install the shower fully. The room has been tiled so big job to remove tiles and reinstall, is there anyway the upstanding for the shower head can be extended?
its a nicky.no name shower but have pics if that will help
help much appreciated
Reply to Mixer shower extension - installed too low, needs to be higher in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left. The pipe work from the shower mixer valve is exposed silver colour pipework. the pipe work will run up from the valve then take a hard left at the ceiling...
1K
hi all i got myself in a muddle. a friend of a friend came around at xmas to help me line up two copper pipes for shower bar install. the pipes were too short and no flex so he introduced me to Hep 2.0. he also did a dry fit and measured everything up to the mm. he left me with some patch work...
2K
I'll start this by saying I'm hoping to sort this by diy / minimal professional help as I'm a very tight budget! I've got a walk-in shower in a wet room. The shower has a tiled-over former with an additional ring of tiles around it. When the shower's in use, a drip comes through into the room...
Greetings. Stranger from the electrician's forum here. Need some plumbing advice please! Our bathroom shower mixer is on surface. The mixer needs changing and her indoors would like a recessed mixer. The problem is that the wall is quite thin and i only have 6cm from front of tiles to the...
1K
I’m installing a new shower bar mixer using a fixing kit which means I have to drill into the tile each side of the pipes to install the bracket. I do not want to hit a pipe, what’s the best way of doing it?
3K
