Discuss Mixer shower - mains cold - gravity hot in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I've seen a few posts about not using mains cold with gravity fed hot.
Ours is only about 0.1 bar for the hot.
The reasons given vary from possible backflow into hot cylinder to hard to get a good mix.
In that case how does the kitchen mixer tap work - that mixes gravity hot and mains cold to give warm water with no extra components as far as I can see. Why can't the same principle be used on a shower?
I've been to a house where on a bath it was a mixer tap with mains cold, and gravity hot, with a shower hose from the tap, and it was always very delicate operation to get a not too hot not too cold shower.
Our hot flows at 5l per minute. So when mixed with mains cold could get maybe 6 or 7 or more if hot is set to a hotter temp, which starts to make a decent shower.
Walter.
It’s more down to the showers arnt designed for low pressure these days too restrictive
Reply to Mixer shower - mains cold - gravity hot in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app 2hrs in morning 2 hrs in evening Any help be much appreciated
