Discuss Mixer shower units in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
AJR48
I have a Mira mixer unit. The flow cartridge is faulty making the tap difficult to turn on. I sent for a replacement cartridge but was unable to remove the exisiting one as it was seized up and the depth of the part where the spanner fits is very narrow causing the spanner to slip off. Even after applying WD40 I could not budge it. The cost of sending for an engineer makes the exercise not worth while so I have decided to get a whole new mixer unit.
My question is this: Is the distance between the hot and cold inlets a "standard" measurement? i.e. if I buy a none Mira unit will it fit?
Alan
Thanks guys. I measured it as 150mm. Mira say it's 153mm. In any case I've found a Triton replacement that shows 150mm +/- 20 so I've ordered that.
no problem!
installation is straightforward, but if you need assistance just post here.
Reply to Mixer shower units in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello! Im Martyn Im new here and have joined for some advice on a couple of things. Ive got an issue with a Mira mixer shower that has increasingly become harder to operate. The shower was installed before I moved into the house. Basically what happens is that I turn the shower on so there's...
Replaced thermostatic cartridge on mixer shower and now water won’t turn off feeding shower head. It’s a Mira agile shower.
1K
Hi All. My Aqualisa Aquavalve enclosed mixer shower valve leaked and gave way and I am looking to replace. I am looking for recommendations what model would I replace it with and how would I replace it if I changed the model! I would like to change the type of model to a lever one. I have...
Hi. I have Charlton Mixer Tap in my shower i.e. thermostat and water control. I need to change the cartridge in the tap as it is dripping badly. However, I'm really struggling to access the cartridge. The way to remove the tap appears to be to unscrew the chrome covering i.e. this will bring...
Could someone give me a heads-up as to the cost of a plumber to replace a thermostatic cartridge in a Bristan mixer bar shower. I have the cartridge, so the cost would be labour only. I live in Norfolk, so not London prices. I had a guy come round this morning quoting me £75 - this seems...
2K
