Discuss Moved radiator from one wall to another in the USA area at PlumbersForums.net
Hi all,
I'm a diy'er, and have previously tackled basis plumbing, fitting sinks, showers etcetra. I live in a two bedrooms bungalow. I have today moved a radiator from a side wall to under the window. This is to allow a bed to be placed on the side wall instead of under the window. All pipework is 15mm. I successfully fitted the radiator, pressurised the boiler, bled the radiators. Everything works fine but, radiators in both bedrooms now do not heat up. All other radiators (x3) in the bungalow however do. Is there something I have missed?
[automerge]1589881114[/automerge]
Sorted. Isolated all radiators, then opened the bedroom ones first. Turned on boiler, h eat comes through. I then turned on all other radiators, and hay presto they all work now.
Reply to Moved radiator from one wall to another in the USA area at PlumbersForums.net
