Discuss Movement between TRV and radiator. in the USA area at PlumbersForums.net
Von
Can anyone tell me if there is supposed to be any movement between a TRV and the radiator, as have replaced a radiator and tightened the connections as much as possible, but the TRV can still be moved backward and forward.
Many thanks,
Von 🤔 🤔 🤔
The body of the valve should be rock steady with a rigid connection to the radiator. A small amount of play in the control knob is normal. I've just tried wobbling a sample of Draytons and the chromed dome moves slightly but it's by less than a millimeter.
Can you provide some details? E.g. a photo and rough indication of how much play you are getting.
[automerge]1580471424[/automerge]
photos of valve was olive brass if so you may not have tightened enough
Were there photos? I'm not seeing any. Actually, post #3 is missing for me. Very mysterious...
Many thanks,
Von 🤔 🤔 🤔
Just to be clear. The connection between the pipe and the radiator is called the valve body ..this has to be watertight and not move. The valve head is the plastic nob that grades from frost through blue to max..these can be a bit loose..did you set the valve head to maximum when you fitted if not it might well wobble ..once fitted turn down to desired setting. Some heads are threaded and others are push on ones but the same principle applies ..centralheatking
Reply to Movement between TRV and radiator. in the USA area at PlumbersForums.net
Hi I have a leaking TRV on a downstairs radiator and need to get it replaced/fixed. Can anyone on here tell me the average cost to have this done...
Hi, I'm looking to add some radiators into my property and ideally looking to match the style of the existing ones. I cannot seem to find...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
C
I have 2 vertical radiators , when the TRV is fitted the radiators fail to get hot. I have replaced both TRVs for new and check the operation of...
1K
Hi, I hope this is the correct place to ask this. I've been given a bunch of smart TRV's to put on my radiators at home. Mostly they've gone on...
