Discuss Moving a window by 200mm. in the DIY Plumbing Forum area at PlumbersForums.net
Not strictly a plumbing question, but to do with the bathroom layout - hopefully not too off-topic! Some pictures attached. What we have is this:
We would like to make this window 800 wide, and then move it by about 100 to the left. I.e., this:
In other words: The gap is currently 720 wide. We'd have to 'fill' about 100 on the right, and 'extend' by 180 on the left, to give us 800. The distance to the wall on the left would then be about 400. (Edit: This would then give an 800 gap, so that a new wider window could be fit.)
Any thoughts about how difficult this would be?
Many thanks!
Björn
If you’ve got the money to pay someone to do it and it’s the design you want, then go for it.
It would likely mean taking existing window/frame out.
Bricking up the right hand side to correct position.
Knocking out top current lintel, installing new extended lintel.
Cutting/knocking out left side to new position.
Install window/frame/make good.
It’s not an overly difficult project.
Thank you!
Reply to Moving a window by 200mm. in the DIY Plumbing Forum area at PlumbersForums.net
Hello all, I'd like to get some advice on the following issue. We have relatively large tiles (see image 1), and the idea was that the vertical...
Hi all, We recently had a ground floor bathroom/wet room finished off, It's about 3.6m long by 2.7m wide, tiled from floor to ceiling and has no...
5K
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
Hello all, I should start off by stating that I'm not in the industry - I'm just a DIYer with a "what-if" idea. Hybrid systems and solar...
1K
Good Evening, We live in an old stone farmhouse which we are steadily 'improving' as the years go by. The heating is provided by a CTC GSi 12...
1K
