Discuss Multimeter uses in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi all
Are there any decent courses to take to help a complete novice learn how to use a multimeter to diagnose boiler faults?
but john reginalds book on combis or central heating, they are comprehensive in how to use them
U tube and installer courses eg baxi, Worcester etc
I haven't got a clue how to use em. I'm now getting sent to break downs and I'm struggling lol
there are a lot more people out there with a lot more know how than me and were just waiting for them, in the mean time boilers are largly switches eg overheat stat switches can be tested in continuity or loads fan gas valve etc which can be tested in resistance so all of your testing is done with power off start safe stay safe and wait for someone to point the way
basicly you need to know two things how to test voltage and how to check for continuity voltage is done live and continuity dead
I would say that unless you have at least a basic knowledge of electrical theory, use of a multimeter then you should not attempt to use it on mains voltages.
You could get an electric shock and/or cause damage to appliancees/ electrical installation.
I had a good kick along time ago which is why I've always been reluctant to mess with electrics. However I would love to be able to fault diagnose boilers.
Just need to get back on the bike and I've had too many to count the best one is when I was young and the back off a plug top broke off and I wanted to use the plug/appliance, so I just pushed it in with my palm of my hand but forgot to switch the plug off :D had a track mark and a mark where the pins where for a good few months after :D
Here is a video showing some of the things you shouldn't do
[video=youtube;_Pmfr5CGDKY]https://www.youtube.com/watch?v=_Pmfr5CGDKY[/video]
Did the Baxi 3 day Combi fault finding and multimeter course last year. Brilliant and not product related, learnt loads. Would recommend
Ideal do a free course called essential electrics, it's basic stuff but there's not much to it anyway. 3 day baxi course is good and you can go back and do the advanced fault finding after you've completed the 3 day course. if you do the baxi course then make sure you ask for the 10% discount as it's usually always on offer
How long is the Baxi advanced fault finding course, did the 3 day at their Warwick centre?
It's just 1 day, but they said you had to wait a month or so to put in practice what you learnt on the 3 day course. I done the course in the Warrington centre so I presume they would have it in Warwick aswel. All you do is spend the full day fault finding on boilers but they put harder faults
Reply to Multimeter uses in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
