- Messages
- 5,439
None of these justify a thread so I'll keep them in the naughty corner
1. You know when some of the jets on a shower head come out at a random angle so you lose full coverage when you stand under it and maybe get an eyefull when you turn it on? What causes that and how would you fix it? Is it similar in cause to the jets on drinking fountains which seem prone to go mental before long?
2. Temp earth continuity bonding. Do you guys actually use it? And are you meant to use it when breaking any run of metal pipe i.e. even undoing a fitting
to remove a tap?
3. If a stopcock or gate valve is really seized, how safe are you generally (speaking from your experience) to wd40 it and give it some serious welly with a tool for leverage or are you running a real risk?
Stay tuned for more...
to remove a tap?
