Discuss My hot water seems far too hot šŸ„µ in the USA Plumbers Advice area at PlumbersForums.net
Deleted member 120897
Greetings members of plumbersforums,
Firstly - long post alert
Iā€™m struggling with my hot water currently - Iā€™ve only mainly dealt with combi boilers, even then, not really had hot water too hot. Anyway I digress, my system is an open vented pre-lagged cylinder, S-plan, Myson 2 ports with a Myson cylinder stat. My hot water seems far too hot, I havenā€™t measured it recently, but when I did a wholeness back, I was getting 68/69 from being set at 60. I reduced it to 40, and was manageable, but still seemed hot. Iā€™ve been been trying to ā€œtestā€ it today, and wifeā€™s has said itā€™s gone worse. Hereā€™s what has been done so far:
  • Replaced Myson with Honeywell temporary, still same issue (although couldnā€™t have wired it wrong)
  • 2port isnā€™t firing boiler by itself (that I know of)
  • Checked spindle on 2 port - is fine
  • Immersion heater isnā€™t on - checked and double checked
  • Checked lever on 2 port head - not fantastic resistance
  • 2 port comes on when I turn dial up on stat, and goes off when I turn it down
  • Noticed just now, cylinder stat no longer clicking
  • When I tested for continuity between orange and grey it brought pump on? But was my multimeter acting as a link?
  • Cylinder stat is making good contact, and worked fine for approx 9 years
  • Felt tank by stat, seems cold?
I have checked wiring from cylinder thermostat and is as follows:
  • Common from programmer goes to terminal 1
  • Thereā€™s a blue wire (assuming switch live?) in terminal 2
  • Nothing in terminal 3
I read it as 3 is call for heat? I asked elsewhere and told call is terminal 2? This is where Iā€™m struggling - can anyone explain it better? Can anyone help me test this properly? Someone has mentioned stratification?
A thanks already in advance
3 is hot water off eg 3 ports easy way to check set your multi meter to continuity
Probe on 1 turn the stat down 3 should beep / circuit and 2 open
Turn temp up 2 should beep / circuit 3 should be open
Where is the stat located in the tank and is touching the cylinder?
Many thanks for the prompt reply Shaun. Yes Iā€™ve already tested that (Iā€™ve got a book by John Reginald - that test is mentioned, although it states itā€™s to find the common wire?).
Tank is approx 1m high, and stat is about 250mm from base to centre. Yes, itā€™s touching copper on the cylinder. After it had been on, I could place my finger in a gap and it felt cold?
Common is live in eg terminal 1
Stat is abit low 330mm is about right 2/3 down from top
When the heating is on the port valve isnā€™t passing correct?
Common is live in eg terminal 1 -thanks
Stat is abit low 330mm is about right 2/3 down from top - ok, might try moving it. It has worked ok though for number of years?
When the heating is on the port valve isnā€™t passing correct? Hmm?
I havenā€™t tried the heating, as itā€™s 2 port and house is like a sauna (only built 2009/2010), so no need for it too be on.
Update - this hasnā€™t worked, although, I did probably need one, as when I removed the head again, a screw hole had snapped. Also not sure if itā€™s relevant, but I hear the boiler fire up, water is heated, then, say 10 mins later itā€™ll fire again? Could it be a thermistor?
Does heating work ?
It did do, I havenā€™t tried it yet, house is warm enough without it just now. Should I try it? If so, how long for, and do I need rads to heat up?
A decent amount of time as that would either confirm or deny if the boilers ok
I might have to wait until colder weather, wife and I already sweating, or do i need to do I to before then? The boiler seems to work ok, I had to replace the fan about 2 years ago due to excessive noise. The heating pump was also replaced, from a Wilo to a DAB evosta.
Is the pipe the flow going to the hot water the same temp as the heating aslong as you havenā€™t had hot water on at the same time as the heating
Reply to My hot water seems far too hot šŸ„µ in the USA Plumbers Advice area at PlumbersForums.net
