Discuss My kitchen tap is leaking from the cold lever in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I have a leak on my kitchen tap it is coming out off the bottom of the cold lever. How do I get the lever off? Also would this tap have a cartridge in the cold & hot or will it be just tap has had it & I need to get a new one?
Unscrew the lever.
This might enable removal of end cap.
There may be a grub screw underneath the handle, if so, remove that and remove cap to access spindle.
Good luck
Reply to My kitchen tap is leaking from the cold lever in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
PSxxxxxx
